BPM push/hold
need a button like on a cdj that 'pushes' the bpm forwards a bit, for when the bpm is set slower than the music. at the moment an on the fly "hold" can be done by double tapping the bpm pause, but there's nothing to nudge in the opposite direction.
current BPM
please can this be visible at all times, please?? not the controls, just the current bpm setting... it's frustrating having to access the bpm tab every time to check what its set at. it could sit
EAsy BPM settings
With a layer selected, hold a 'shift' type button + 1/2/3/4 to set it straight to that many beats. clicking up and down to get to say, 2 beats from 8 means sctolling throuhg 7,6,5,4,3 which must be a drain on the cpu to be trying to work that out as you go and is awkward and messy.
Video mask;
The freeframe output mask is great... will the new version of resolume/FF allow this to be set to a grayscale video? that would be great.
Hyperthreading support.
ive run resolume on a dual processor computer, as im sure many people do.... seems a shame not to use the extra processor power.
thanks guys!!
That is all.
Looking forward to 3.0
