which MIDI keyboard
janosch_
Post by janosch_ »
high guys,
i tried resolume out... and it´s love on the first sight... I`ll buy it today
but its a little hard to scale the effects by mouse. so Im looking for a Midi keyboard which also can control the adjustment of the effects by "these small turnable buttons" (incredible gud enklish:-)
so which keyboard do you favourite?
stark_
Post by stark_ »
hi,
i really like the doepfer pocket dial
its really a knob midi controller, which is cooler than a midi keyboard. I have not used it yet, but I am planing on buying it because it can be used to control effects, etc.
check it out at http://www.doepfer.de
they also have a pocket fader.
jason_
Post by jason_ »
oxogen
yeah go for a small oxygen 8 keyboard ... it,s cheap, small, has keys, knobs, sliders and will make you look like a rockstar!
andrew_
Post by andrew_ »
I've got the oxygen - excellent bit of kit but not quite enough keys to trigger all the clips and the effects that I want - thinking of the edirol pcr 30 - anyone using this? it also has a set of sliders to control effect levels, blends, speeds etc etc
martijn_
Post by martijn_ »
oooh,
I thought I had allready replied to this one.
recently bought the PCR30.
The extra 8 sliders and assignable 9 buttons are invaluable.
Indeed you can use these sliders to control playback speed, playhead position, effects, you name it.
In my opinion the controls work and feel better than the oxigen and evolutions keyboards/controllers.
You can download a little app to program the controllers and manage it's memory :)
Great piece of equipment.
martijn
ollie_
Post by ollie_ »
i've got the pcr30 and yes it rocks.
whats this lttle app you mention to program the controllers?
cheers ollie
martijn_
Post by martijn_ »
you can download it at edirol.com. It's called PCR Edit
Martijn
