Hello, I can't get the edirol v-4 mixer to read windows xp using bootcamp on my macbook, so can't use resolume.
The apple platform works fine with the edirol so does my pc which has installed the same copy of windows I use on the mac. I can project the windows platform with resolume straight from my macbook to the projector with the edirol not connected.Thanks if anyone can help.
My edirol-v4 does not read windows xp using bootcamp
BuckRogers
Re: My edirol-v4 does not read windows xp using bootcamp
1. Check the NTSC/PAL settings on your V4 and/or Mac. It's most likely the source of your problem.
2. Make sure you use the composit out on your DVI-video adapter
Thanks for the replay. This could be the problem but I can't find the PAL settings on the windows platform on my macbook.
