HI
hope everyone is cool and looking forward for the hot summer..
i have to produce a DVD with my visuals to be projected on a screen.
i m wondering which is the best way to do it.
- which resolution video clips should i use for projection.
i have premier and vegas.
thanksssssss
						VISUALS DVD
				coolhandloop
Re: VISUALS DVD
720x 576 is the standard resolution for dvd . if you compile in premier and then encode in premier also this will compress for dvd with little loss of quality (depending on how long the dvd will be)
once its transcoded i usually burn in adobe enciore .this is handy if you want to make menus ,or map oput dvd ...other wise you can burn straight to dvd from premier ( pro upwards)
