Is it possible to save decks onto a portable flash memory stick?
I often VJ using other peoples laptops. I run my content off a fast 8gb stick, but would like to save the decks onto it too, to save setting them up every time i use a different machine.
Can anyone help?
Saving resolume decks onto a memory stick?
Re: Saving resolume decks onto a memory stick?
It should be possible but name/letter of the disc on your computer where your clips originally are should be same as on the stick.
So before the show, put deck file into My Documents and change the name/letter of your flash. That should do it. But the best way is to try
