Pharelia Matrox
I'm pretty sure if you use the DVDmax (aka overlay) function on your machine - your output will be 320x240 no matter how you tweak it. This will explain why your flash files look jagged - to get full res you will have to use dual screen (loosing your preview) and run the output @ 640x480. Your flash files will look fine at this res.
Hi guys,
DVD-Max just takes the output and scales it to your second screen output so if u use higher res output the video will be better... but i found that DVD-Max is a bit processor UNfriendly... because when i use 3 layers of video 320-240 indeo without DVD-Max it works fine but with it starts to lag.
i recommend using the zoom function on the little output window at the rigth top of resolume. only problem is that u get only 320-240 output but with filter enabled it looks pretty good...
and Plouf the flickering is because your refreshrate is higher than most beamers can handle.. if u set your second screen to 50 Hz it will work fine.(had the same problem)
Good luck, SuperficiaL
