simple problem
vjcharm
simple problem
Post by vjcharm »
Sorry if this seems remedial, but I want to assign key shortcuts to global effects in resolume 2.4.1 (seeing as you can't save them). However, a lot of keys are currently assigned to channels, but since I use a midi controller, I don't need these. I notice that under preferences, there is a "clear all", but I remember I hit that and bad things happened. I just want to clear the key assign for the channels, that's all. Is there an easy way to do this?
Also, another kind of silly question, but how do you clear a clip from a channel after you've dragged it there? Nothing I do seems to get rid of it. Thank you.
VJair
Re: simple problem
Post by VJair »
vjcharm wrote:Sorry if this seems remedial, but I want to assign key shortcuts to global effects in resolume 2.4.1 (seeing as you can't save them). However, a lot of keys are currently assigned to channels, but since I use a midi controller, I don't need these. I notice that under preferences, there is a "clear all", but I remember I hit that and bad things happened. I just want to clear the key assign for the channels, that's all. Is there an easy way to do this?
in the preferences, select the parameter you want to remove the shortcut from by left clicking once, then when it shows it the box click the X next to it
vjcharm wrote:Also, another kind of silly question, but how do you clear a clip from a channel after you've dragged it there? Nothing I do seems to get rid of it. Thank you.
doing a search in the manual and typing clear gives this as the first result....
"To empty a channel press ALT & 'channel shortcut'. (so ALT & 1 clears the top left channel)"
vjcharm
Re: simple problem
Post by vjcharm »
Okay, great, thank you. As a side note, for the global effects key trigger seems a little weird, it seems that if you assign to a letter, that doesn't work until you actually drag an effect to a slot, otherwise hitting the letter just jumps to the effect starting with that letter, a la windows explorer. Is there something I'm doing wrong?
vjcharm
Re: simple problem
Post by vjcharm »
Okay, I couldn't get the clear channel key to work. All I see is a clear all "x", when I left click on the key, nothing happens.
VJair
Re: simple problem
Post by VJair »
vjcharm wrote:Okay, I couldn't get the clear channel key to work. All I see is a clear all "x", when I left click on the key, nothing happens.
are you talking about getting rid of a video from a slot.... thats what you cant do?
vjcharm
Re: simple problem
Post by vjcharm »
No, I just want to get rid of key trigger so I can assign those keys to the effects, since I use midi anyway. If I select clear all, it clears EVERYTHING, which is not what I want.
VJair
Re: simple problem
Post by VJair »
then dont choose clear all, use the x next to the box.
vjcharm
Re: simple problem
Post by vjcharm »
VJair wrote:then dont choose clear all, use the x next to the box.
The X is the clear all.
