Can I create a canned video performance
Jim Jackson_
Post by Jim Jackson_ »
I would like to create a canned video performance and then be able to walk away from the workstation while the program plays the session. Is this possible? Seems to be great software BTW. This would be like queuing up 30 to 50 viseos at once and letting it run for four hours. If I can do this I would also like to insert an advertising clip every so often so that the order would be video 1, video2, video3, video4, ad1, video5, video6, video7, video8, ad2, ect... Let me know if it can be done.
Thanks,
Jim
komar_
Post by komar_ »
make some tests with the chaos functiun of the soft,i did it with a painter's work to give a random show,it was fine !
martijn_
Post by martijn_ »
try considering a midi sequencer (soft- or hardware).
I did some tests with it and it works great. I used cubase sx, you van even modify controllers (fades, clip speed, etc) with it.
It's quite a lot of work, but when you're done, you can walk through the crowd with a 'fake' remote control, pretending to be VJ-ing 'live' :)
Martijn
