resolume stops working while sequencer is active
Alexander_
Post by Alexander_ »
I would like to trigger effects with cubase.
But when i switch the application resolume stops working.
Is there any workaround, that dosen´t stop the resolume engine while working in another programm?
martijn_
Post by martijn_ »
another option is to have cubase running on another PC/laptop. You can use dMidi to route the midi signal through a network http://www.dmidi.org to the resolume machine
Martijn
Alexander_
thx
i know, but i don´t wont a laptop more for a thing which is just a software ajustment.
does anyone know why resolume stops output if prog is not the active one?
could it be changed?
greetings Alexander
