hi, i was thinking resolume should have a total mask-like option..
i explain.
for example, a way to play with f1 f2 and f3 position, sizes and repetition.
they way i thought it could work is by making a flash file with some special info in it that would tell resolume where to put f1 f2 and f3 using symbols. This would allow you to do picture in picture kind of things, for example, having a live cam at the corner. And also having special tile effects like checkboard like screen with f1 and f2, the possibilities for customization are endless.
It would also be great to have backgrounds, or foregrounds. and text added, so the video can be played inside an image, or a flash movie.
what do y'all think?
ideas, ideas
Alexander_
all you ask for is provided by the freeframe plugins.
See diskussion about (http://www.resolume.com/discussion/i-ms ... pic_id=414)
the only problem is, that you need more than 1 parameter, which is actually only possible at the final effect.
Would be great to can modyfy more than 1 parameter with
resolume.
greetings
resolume.
greetings
