Resolume won't fit onto my screen
Hi- I'm a bit of a newbie to resolume..managed to get it up and running on my sony vaio on xp. But everytime it loads it won't entirely onto the widescreen and runs off the side so you can't view the controls properly. Any ideas would be very much appreciated
Re: Resolume won't fit onto my screen
Have you tried to change screen resolution.
Yeah please tell use your screen resolution.
Btw: if it did boot up the first time you used it, it can also be caused by resolume itself (if you changed some screen settings in resolume).
You can undo this by deleting the preferences.xml file in the resolume/settings folder, it's located somewhere in your user documents and settings folder (don't know the path in xp).
