connecting wiimote and mpd24
yochee
Post by yochee »
Hey Resolumers!!
I would like to connect my wiimote and a Akai mpd24 to resolume at the same time. So that I can trigger the clips and the effect parameters with the mpd24 while choosing layers, effects and anything else with the wiimote buttons.
Until now I can use booth separately without any problems, but somehow I cant get em work together, the wiimote signal always disappears when I connect the mpd24??
Im using GlovePie, MidiYoke/Ox on WinXP.. with standard preferences.
In Resolume Im getting MIDI Signals from MIDIYOKE 1-8 and USB-Audiointerface 1-3.
After eliminating the MidiInputs
- the mpd24 midi runs as "USB-Audiointerface 1"
- the wiimote runs as "In from MIDI Yoke: 1"
so it seems like the occupy the same MIDI port (1). Do I have to remap then or what?
And how can I do this? Should I remap in MIDIOX, GlovePie or in the mpd controlprogram? I was trying hard, but cant find a way, im just not such pro at MIDI-mapping ;)
Maybe you can help me finding a way to do this, even though we are all waiting for thursday :)
yochee
Re: connecting wiimote and mpd24
Post by yochee »
omg, more then 50 views on this topic but no reply?? thats a pitty..
it must work somehow, since u can can get analogue midi controllers connected in a row.. should i work with another midi program like hubis..? please give me a hint, since its really annyoing trying to eliminate midiports in 3 programms and to see its still not working :roll:
but ill keep trying..
yochee
Post by yochee »
okay tryied loopback.. works fine!! thx for nothing ;)
cant wait tomorrow, gdn8
http://loopbe1.nerds-de.qarchive.org/_download2.html
