Resolume and Bootcamp or VMWare Fusion
Hi I'm using resolume on my windows laptop, recently I bought a brand new Imac 24inch. I thought of using resolume on it with Bootcamp, but when I try the video-out this gives problems. Is there an other solution which works? VM ware fusion for example?
Re: Resolume and Bootcamp or VMWare Fusion
i suggest waiting until the 2nd of october until the new version of resolume is released which runs on mac os as well as pc nd see how well that works on your machine.
Uhu, that's a possibility, but what if I like resolume 2.41 and still want to use it;-)
if you want to use R 2.41 you will have to use windows.
What problems? I use it on my macbook pro, it works much better than in my toshiba laptop
