Keybord Mapping
VJzoo
Keybord Mapping
Post by VJzoo »
not sure if im just not seeing it but im trying to assign = and - to speed up and slow down globally if thats possible in R3, like r2 did.
also toggle direction of timeline instead of </> using one key.
or maybe im just not seeing it :?
wuzzle
Re: Keybord Mapping
Post by wuzzle »
I too would love a global setting for speed, but it looks like we can only currently set things that are visible controls. perhaps once the buglets are hammered out we can beg for that to be added 8-)
VJ Wuzzle
Shakti Collective - Toronto, Canada
serik
Re: Keybord Mapping
Post by serik »
I am also missing the oppurtunity to set (and map) the speed of a whole layer. Would be great to be able to something like this in the layer properties. If you want to change the speed with a midi keyboard potentiometer I guess you would have to have a knob for every clip ... and I have only 16. ;-)
VJzoo
Re: Keybord Mapping
Post by VJzoo »
have got speed working for active clip using a uc33 controller but still cant get the toggle direction using one button or midi note.
Jas
(the dyslexic VJzoo)
http://vjzoo.com
~ quite nice visuals ~
Re: Keybord Mapping
VJzoo wrote:...but still can get the toggle direction using one button or midi note.
No this is indeed not yet possible, so far it is only possible to map items that are visible in the interface, we have to think of a way to map some clever invisible things like global speed and direction toggle. It's on our todo.
VJzoo
Re: Keybord Mapping
Post by VJzoo »
brilliant :)
i'm having a ball with R3 so will be great to get more midi/keyboard control.
Jas
http://vjzoo.com
JERREM
Re: Keybord Mapping
Post by JERREM »
Hi all,
my first time on the forum, 1st id like to say well done with avenue! its simply awesome. rev1110 has some good improvements too!, but it still seems to be missing some key mapping ablities. such as forwards backwards key as vjzoo suggests (much missed)
could i suggest that there might be away to map multiple things to the same key? i.e. "\" mapped to both forwards and backwards so you can toggle between the two, likewise we could also map a play/pause key. as far as i could see this could be really useful, i would also map clip keys (1-0) so on first press it previewed the clip and on second press it triggered it as well as toggling through blending modes, decks, property panels etc...
I think this could be an option in the mapping interface, the selected key could show up with a number (this being the order of triggering). It would also as be useful to map more than one key to the same selection.
http://www.jerrem.com
Artist, VJ & New Media Activist
VJzoo
Re: Keybord Mapping
Post by VJzoo »
Just been testing 3.1 and still have this same issue. is there any way around the issue? i.e toggle direction of clip assignd to one key and Global speed.
Jas
http://vjzoo.com
Re: Keybord Mapping
No workaround for this yet but it's on our todo, we wanted to get this done for 3.1 but Flash took longer than expected ;-(
VJzoo
Re: Keybord Mapping
Post by VJzoo »
Cool Good to know its still on the todo list :)
Jas
http://vjzoo.com
