bugs found by RabosaVJ
rabosavj
Post by rabosavj »
1st Problem
If i load one source to a layer and i try, for exemple gradients minimize the gradient propertie and then try to maximize doesn't work.
2nd Problem
Maximie-minimize Output monitor doesn't work
3rd Problem
Output->Advanced-> if i select the same as i have the interface and i move the window properties crash resolume avenue
4th Problem
(i only could reproduce it twice) resolume crash when i try to insert and delete layers and if i delete a desk is active crashes as well.
