BPM SYNC only working in loop mode
incuf
Post by incuf »
When I set a clip to "BPM sync" mode, the clip will play in sync but only in "loop" mode. if I change it (bounce or once) it will still play in loop mode.
so far the only BIG bug i found. It crashed once when switching from timeline to BPM sync.
I´m running a MBP 4GB 256Mb video, photo jpeg 640 x 480
Anyone with this problem??
cheers
Frank
incuf
Re: BPM SYNC only working in loop mode
Post by incuf »
I installed it on a PC, and same problem. It appears that "cables" on the back of "bounce" "once" botons are "unplugged"
Everything else really nice!!!!
I don´t think is a problem with my computer, since I tried it in Mac and PC with the same problem. What about you guys? Does it work for anybody?
cheers
edwin
Post by edwin »
You are right that it doesn't work, it hasn't been implemented yet. It does work for audio clips though.
So it's up on our list and there is nothing wrong with your computer :)
incuf
Post by incuf »
Thanks!!! althouh it´s a shame I can´t use it till this works. I would have to modify my loops so that I don´t need the bounce option. If you say that the official full functionality version is around the corner I won´t bother in doing that nasty job.
I´ve tried for a couple of hours and I reaaaaaally like it, great job!!
cheers!
