Crashing Ave
alexius420
Crashing Ave
Post by alexius420 »
So I have an IBM thinkpad with a
256 nvidia nvs 140m
Intel Duo Core t7300 @ 2ghz
2gigs of ram -778mhz
Win Xp SP3
The program starts and the computer Voice says " resolume avenue " .While the voice is playing , i can see the resolume logo moving in the top left window. As soon as it finishes say resolume avenue it just crashes out. Have attached resolume log. PLEASE HELP :? :? :geek: :mrgreen:
Resolume Avenue 3 log.zip
My resolume log file .txt
(3.21 KiB) Downloaded 896 times
edwin
Re: Crashing Ave
Post by edwin »
I saw in the log that it fails when trying to load the Demo composition. Maybe you can try removing that composition from your computer. It's in your installation folder in the default folder. And it is probably also copied to your C:\Users\[name]\Documents\Resolume Avenue 3\compositions folder.
removed it from both places and try loading your own files.
Edwin
alexius420
Re: Crashing Ave
Thanks ! that totally worked.
Now , i can load the demo audio beats and things and they play fine, but when i add a demo clip or an avi file it crashes out again. Could you take another look at new log file for me !
Resolume Avenue 3 log.rar
(1.72 KiB) Downloaded 1058 times
edwin
Re: Crashing Ave
Post by edwin »
What kind of files are you trying to load. What Codec is used for your avi files.
The demo clips seem to be crashing the application on your machine, which is weird because they are standard Cinepak encoded VFW files. So i would try loading your own clips.
Only VFW compatible .avi's are supported and of course Qcuiktime files as well.
alexius420
Re: Crashing Ave
I am loading my avi files to the program. I have tried different codecs ,xvid,divx,k-lite, etc but they all do the same. I have even converted video to a basic avi format . still doesnt work. Any suggestions on what codec pack to use? or what i should convert clips too? Im using xilisoft to convert my videos.
I installed only one codec at a time then tried it. If it didnt work i would uninstall codec , install new one , then reboot, and try again.
Im sooooooooo close to running this !!!! Im so excited :mrgreen:
Once again thanks alot for all your help bro. ! :ugeek:
I sing the praises of resolume everywhere i go ! :o
alexius420
Re: Crashing Ave
ok so i dl some vj loops from internet archive .mov and they work ! :mrgreen:
so my question is now, how should I encode them avi? how should i put the settings,( bitrate,size ,aspect ,etc...) in my converter? :mrgreen:
wuzzle
Re: Crashing Ave
Post by wuzzle »
alexius420 wrote:ok so i dl some vj loops from internet archive .mov and they work ! :mrgreen:
http://www.resolume.com/avenue/manual/
Check the Preparing Media section :)
VJ Wuzzle
Shakti Collective - Toronto, Canada
