macbook not working
ropke
macbook not working
Post by ropke »
just because i kinda like this pic ;)
edit:
report sent by mail :)
ropke
Re: macbook not working
Post by ropke »
ok, wrong video chip. end of story :ugeek:
incuf
Post by incuf »
I guess it won´t work on mackbook, as it shares video with RAM. You´ll need a MBP!!
cheers
edwin
Post by edwin »
It can work on a macbook, but it depends which model you have. We had it running on a Macbook which was bought a few months ago. Check wether your videocard is Opengl 2.0 compatible. Also check wether there is a pending software update for OSX. We will have a look what we can do to support more models.
EGGATRONIX
Post by EGGATRONIX »
Macboook a no no
I've got the same problemo running Avenue on my macbook. I have no "output monitor" which sucks.
I guess its something to do with my graphics card. Boo hoo
Maybe its time to get a Macpro.....
Model Name: MacBook
Model Identifier: MacBook2,1
Processor Name: Intel Core 2 Duo
Processor Speed: 1.83 GHz
Number Of Processors: 1
Total Number Of Cores: 2
L2 Cache (per processor): 2 MB
Memory: 2 GB
Bus Speed: 667 MHz
Boot ROM Version: MB21.00A5.B07
SMC Version: 1.13f3
Serial Number: $%&^&^&*(**^$£$@
Sudden Motion Sensor:
State: Enabled
Chipset Model: GMA 950
Type: Display
Bus: Built-In
VRAM (Total): 64 MB of shared system memory
Vendor: Intel
Device ID:
Revision ID:
Displays:
Color LCD:
Display Type: LCD
Resolution: 1280 x 800
Depth: 32-bit Color
Built-In: Yes
Core Image: Hardware Accelerated
Main Display: Yes
Mirror: Off
Online: Yes
Quartz Extreme: Supported
Display Connector:
Status: No display connected
