Pocket fader midi controller
Adry_
Post by Adry_ »
I've bought the Pocket Fader (Doepfer) to use on Resolume. But all the manual is in German. Is anybody know how to use this controller and can help me ?
Thanx !
we do not have the pocket fader but it,s not just a case of connect and go? i though so ...
Adry_
Post by Adry_ »
I've found the english manual, but the controller doesn't run. It's not a USB. It work with midi plugs, and i've plug it on joystick. It's not very simple to configure...
komar_
Post by komar_ »
try http://www.apak.netit's the dopfer importater in france,maybe they may help you
Adry_
Post by Adry_ »
What midi channels do Resolume use ? And how to select the good parameters on a midi controller ?? Help !!
Adry_
Post by Adry_ »
Apak.net give no answer to my mails...
Dan_
Post by Dan_ »
check out the midi assignment tab of the options window.
You just select the parameter you want to control and then move the relevent midi controller. It's as easy as that. You don't really need to understand midi at all to use it (but I would recommend that everyone learns at least the basics about midi)
Dan.
Adry_
Post by Adry_ »
Yes, I know, but with this controller, it's not so simple !
I've tried with a Evolution UC-16, and that's run very simply !
Adry_
Post by Adry_ »
