BUGS: Various
craftycurate
BUGS: Various
Post by craftycurate »
1) No output on second monitor, whether windowed or fullscreen. One one occasion, one frame from an AVI did appear on display 2.
I have the latest NVidia Drivers (v175) for my graphics card (NVidia Go 7900 GS, 2556MB, OpenGL 2.1)
2) Does not recognise any ASIO audio drivers e.g. Novation Nio (USB sound interface) ASIO drivers. Crashes while selecting Novation Nio as an ASIO device from the Audio Output Device Options.
3) Playing Indeo 5.1 Clips backwards backwards is jerky - not as smooth as Res 2.41 (Keyframe every frame, 100% quality)
3) Decks sometimes load in reverse order when reloading composition
4) Has trouble loading VST audio plugins - have tried a few - sometimes freezes with white screen on startup. The ones that need to sync with host clock did not function, and a distortion plugin loaded but the plugin interface did not appear, and it had no effect on the clip audio (even though I was able to alter parameters, the sound did not change).
5) Some key mappings are not stored with the composition - I have to add F1-F3 each time (used to activate Layer 1,2 and 3)
XP Pro SP2, Novation Nio USB Audio Interface
