I have a Mac Book, just bought it three weeks ago, so it is quite up-to-date I guess. It is the black one with 2.4 GHz etc.
Resolume basically runs fine, also doing proper output on a 2nd screen. Unfortunately it crashes after about 5 minutes. This crash is reproducible, it is independent from what I actually do in the program. Log is attached.
Also I might add that I use a Japanese macos, so there could be problems with path names. However I did not access any clips saved under a Japanese pathname. It seems like the Avenue file browser cannot display Japanese filenames/directory names.
Suggestions:
1) full screen mode for the GUI
2) position / resizing of the menus is saved with exit or can be saved in preferences
3) I used to do beat sync switching between the layers a lot (no fading). Is this possible with Avenue already?
Cheers from Tokyo,
k
OpenGL Extension Viewer Report:
Renderer: Intel GMA X3100 OpenGL Engine
Vendor: Intel Inc.
Memory: 128 MB
Version: 1.2 APPLE-1.5.30
Shading language version: 1.20
Max number of light sources: 8
Max viewport size: 2048 x 2048
Max texture size: 2048 x 2048
Max anisotropy: 16
Max samples: 0
Max draw buffers: 4
Max texture coordinates: 8
Max vertex texture image units: 16
Extensions: 82
GL_APPLE_aux_depth_stencil
GL_APPLE_client_storage
GL_APPLE_element_array
GL_APPLE_fence
GL_APPLE_flush_buffer_range
GL_APPLE_flush_render
GL_APPLE_object_purgeable
GL_APPLE_packed_pixels
GL_APPLE_pixel_buffer
GL_APPLE_specular_vector
GL_APPLE_texture_range
GL_APPLE_transform_hint
GL_APPLE_vertex_array_object
GL_APPLE_vertex_array_range
GL_APPLE_vertex_program_evaluators
GL_APPLE_ycbcr_422
GL_ARB_depth_texture
GL_ARB_draw_buffers
GL_ARB_fragment_program
GL_ARB_fragment_program_shadow
GL_ARB_fragment_shader
GL_ARB_multitexture
GL_ARB_occlusion_query
GL_ARB_pixel_buffer_object
GL_ARB_point_sprite
GL_ARB_shader_objects
GL_ARB_shading_language_100
GL_ARB_shadow
GL_ARB_texture_border_clamp
GL_ARB_texture_compression
GL_ARB_texture_cube_map
GL_ARB_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat
GL_ARB_texture_non_power_of_two
GL_ARB_texture_rectangle
GL_ARB_transpose_matrix
GL_ARB_vertex_blend
GL_ARB_vertex_buffer_object
GL_ARB_vertex_program
GL_ARB_vertex_shader
GL_ARB_window_pos
GL_ATI_texture_env_combine3
GL_EXT_abgr
GL_EXT_bgra
GL_EXT_blend_color
GL_EXT_blend_equation_separate
GL_EXT_blend_func_separate
GL_EXT_blend_minmax
GL_EXT_blend_subtract
GL_EXT_clip_volume_hint
GL_EXT_draw_range_elements
GL_EXT_fog_coord
GL_EXT_framebuffer_blit
GL_EXT_framebuffer_object
GL_EXT_geometry_shader4
GL_EXT_gpu_program_parameters
GL_EXT_multi_draw_arrays
GL_EXT_packed_depth_stencil
GL_EXT_rescale_normal
GL_EXT_secondary_color
GL_EXT_separate_specular_color
GL_EXT_shadow_funcs
GL_EXT_stencil_two_side
GL_EXT_stencil_wrap
GL_EXT_texture_compression_dxt1
GL_EXT_texture_compression_s3tc
GL_EXT_texture_env_add
GL_EXT_texture_filter_anisotropic
GL_EXT_texture_lod_bias
GL_EXT_texture_rectangle
GL_EXT_texture_sRGB
GL_EXT_transform_feedback
GL_IBM_rasterpos_clip
GL_NV_blend_square
GL_NV_light_max_exponent
GL_NV_texgen_reflection
GL_SGIS_generate_mipmap
GL_SGIS_texture_edge_clamp
GL_SGIS_texture_lod
Core features
v1.1 (100 % - 7/7)
v1.2 (100 % - 8/8)
v1.3 (88 % - 8/9)
v1.4 (93 % - 14/15)
v1.5 (100 % - 3/3)
v2.0 (100 % - 10/10)
v2.1 (100 % - 3/3)
v3.0 (28 % - 6/21)
OpenGL driver version check (Current: 1.2 APPLE-1.5.30, Latest known: 1.2 APPLE-1.5.30):
Latest version of display drivers found
According the database, you are running the latest display drivers for your video card.
No compiled vertex array support
This may cause performance loss in some applications.
Multitexture support
This feature accelerates complex rendering such as lightmaps or environment mapping.
Secondary color support
This feature provides an alternate method of coloring specular highlights on polygons.
S3TC compression support
This feature improves texture mapping performance in some applications by using lossy compression.
Vertex array range support
This feature improves performance in some applications by using AGP for dynamic vertex transformation.
Texture edge clamp support
This feature improves texturing quality by adding clamping control to edge texel filtering.
Vertex program support
This feature enables a wide variety of effects via flexible vertex programming (equivalent to DX8 Vertex Shader.)
Fragment program support
This feature enables a wide variety of effects via per pixel programming (equivalent to DX9 Pixel Shader.)
Texture anisotropic filtering support
This feature improves the quality of texture mapping on oblique surfaces.
Occlusion test support
This feature provides hardware accelerated culling for objects.
Point sprite support
This feature improves performance in some particle systems.
OpenGL Shading Language support
This feature enables high level shading language for shaders.
Frame buffer object support
This feature enables render to texture functionality.
Extension verification:
avenue on mac book
Re: avenue on mac book
forgot the attachment, the extension is changed to .zip, but it is the original text file.
- Attachments
- avenue.zip
- (148.45 KiB) Downloaded 648 times
I can't seem to open the .zip file. Could you try attaching it again?
Hello,
please rename the .zip file to .txt
Your forum does not accept uploading files with e.g. the extensions .txt or .zip
sorry, i meant the extensions .txt or .log (the two that i tried before renaming to .zip)
actually it seems like the crashes might be in some way related to browsing files. At least it doesnt hang up from just playing the demo clips (so what i wrote in the earlier post was not correct). The probability of crashing is higher when i start loading/switching/removing. For external clips i used the robots footage pack from the resolume website to make sure i dont run into codec problems.
