Hi peoples
My question is about capturing live video on a matrox g450 etv. I want to capture live analog video with this card in resolume but when i choose the vidcap capture driver in my generator menu it works a little bit but when i drag it in one of the channels it displays just a white square, what is the problem, and what could be the sollution. Thanx
capture live video
i have used a miniDV camera into resolume using firewire. Seems to work OK. Just have camera on and plugged in before you start up resolume - DV driver should appear in hte "capture drivers" menu under generators.
Do a lot of testing before you use it in a performance though - i have some issues with feed "pauses" and short lock-ups when using DV
