timecode vinyl in resolume?
yochee
Post by yochee »
okay, this goes beyond. but what about implementing timecodevinyl into resolume?
You might know good and bad programms which all can play wav/mp3-files with a timeline-view. (Just to name some: classic: Serato & Traktor Scratch or cheap: reloop spin etc.). Most of them need an analog/digital (asio)interface to get the timeline signal. Maybe this even could be solved easier by using some vestax vci midi interface (www.vestax.de) and assigning video channels/clips and playheads to the new resolume scratch fader (A/B).
But some people just wanna play real vinyls. So what about that? I think this would be interesting, because no timecodevinyl-dj-program does play videos. So this would make resolume a real turnie/lappy based svm-1000 with the capability to mix wav/mp3! (okeh, u will have to support mp3 first and recode the resolume surface to some djfriendly design..)
There is another softwares, which does not need any analog/digital-interface but which plays the timecodevinyls. Its called Quad2 (www.schaack-audio.com/quad.html)...
Damn, gotta learn C.. :)
VJair
Re: timecode vinyl in resolume?
Post by VJair »
yochee wrote:no timecodevinyl-dj-program does play videos.
Serato VIDEO-SL plugin for Scratch Live
http://createdigitalmotion.com/2008/01/ ... ual-vinyl/
yochee
Post by yochee »
okay my fault! I should get some more info before posting :)
yochee
Post by yochee »
but on the other hand for the Serato- video plugin you will need a special audiomixer (TTM-57SL) and the analog/digital interface (+turntables). I dont think serato can play mutlilayer/multidecks/multiinput (e.g. from cammy).
I want the videos (and audio) to be mixed by the laptop, then only the turntables and a laptop would be needed..
Yeah we would love to and should not be too hard with Ms Pinky and it's SDK:
http://www.mspinky.com
But i'm sure you,ll understand that this is not at all our priority at the moment.
yochee
Post by yochee »
sure.. it just came to my mind at the looking at the timeline:)
disorientalist
Post by disorientalist »
Theres also Virtual Vinyl by Numark that uses timecode vinyl to manipulate video. Not sure if it is any good in terms of quality and stability. Serato Video-SL appears to have a lot of hype surrounding it but it goes back to the two decks and a mixer paradigm (at the cost of an arm and a leg), whereas Resolume 3 has the potential to be a lot more versatile (and is a lot cheaper). Ofcourse, if someone can get ms pinky to work with resolume then you've got the best of both worlds. I think I might give it a go meself :D
Mudo
Post by Mudo »
Did it...
Ms Pinky sends Midi 7 or 10 bits resolution pitchbending (sysex) and OSC.
put the pieces in place...
yochee
Post by yochee »
... and three years + 1 day later you got this:
Shorties
Post by Shorties »
yochee wrote:... and three years + 1 day later you got this:
Wow that is very cool.
