hi folks!
anybody knows anotherway than livids batch video exporter to convert avis under windows to movs with photo jpg codec?
the livid software crashes on my macbookpro ( leopard, bootcamp).
i tried several joices but they didnt help.
thx
vijay sikanda
http://sikanda.sonance.net
converting avi with windows codecs to quicktime photojpg
Re: converting avi with windows codecs to quicktime photojpg
I find QTAmateur fast, free and easy. Runs under OSX, has a batch mode. I used this to convert a couple thousand clips when I migrated from PC to Mac, only one problem, Mac will not read the Indeo codec, had to convert some of them on the PC to MJpg first.
Roovid Lite do the job!!
you can drag & drop avi files into a preset, and just wait for the mooooovvvv
cheers
cheers
