Hello everyone!
Just wondering if there was any way to Reset Keyboard Mapping? I erased contextual and direct while trying to figure out midi mapping...which is also messed up...and now the keyboard is gone too. Any way to get back the presets?
Re: Reset Keyboard Mapping?
You can throw away the contextualKeyboardShortcuts.xml and the contextualMidiShortcuts.xml files in:
C:\Documents and Settings\[user]\My Documents\Resolume Avenue 3\preferences
And then the default presets are loaded the next time you start Resolume
Exactly what I needed! Thank you. Thank you. Thank you. Amazingly when I reset this way my trigger finger that had previously not worked with midi - worked like a charm. Sweet.
