run as user under W2K
Willard van Delft_
Post by Willard van Delft_ »
When I install Resolume as administrator under w2k how can I get it to work under a normal 'user' account? I tried auditing for acces failures on files but nothing came up.
I'm running W2k sp3 with a matrox G550 dualhead.
Some of our students are interested and I'm not giving them administrative privileges...
Larenstein / EMLA administrator.
resolume should work installed as any user on win2k so i can,t really solve your problem now. mayee someone else has a sollution for this?
Groeten aan David ;-)
Rob_
Post by Rob_ »
Make sure that that user has admin right on the computer, either logon to the computer as administrator or creat a user account and give that user admin right (add them to the admin group). If the computer you are using is part of a domain you will have to get the domain admin to add that user to the local administrato account on the computer. If you have created a basic user and not added them to any admin group they will have very limited use and if Resolume creates a user account or writes a file out that user will not have rights to create them.
