duplicate clips
Rene
duplicate clips
Post by Rene »
Hello,
Yesterday when I was creating a new layer/composition, after adding all the clips, scaling, applying effects, configure effects, etc. I wished that I could copy or duplicate an existing clip (let's say clipA) of a certain layer. I just wanted to add another effect to clipA and store it as new clipB. Is there a way to do this without starting from scratch importing the "raw" footage to the layer and again attach all effects (including configuration of all parameters, etc)?
levon
Re: duplicate clips
Post by levon »
There are a few things you can do with moving/copying and merging clips in Avenue.
if you click and drag on the name of the clip before you release, hold down CTRL and you will duplicate the Clip
Hold down ALT to Swap the Clips.
And if you drag an Audio clip onto a Video clip (or vice versa) holding down SHIFT, you can merge the clips together.
You can also hold down SHIFT + ALT when dragging an audio clip onto a video clip to merge the 2 clips.. as well as leaving the original clip.
Rene
Re: duplicate clips
Post by Rene »
Thanks levon! - This CTRL key makes life easier! :D
faza
Re: duplicate clips
Post by faza »
hi - is there any way to copy only effects from the clips , layers or composition ? I now that i can move effects around bay simply dragging it , but I need to copy it... Thanks in advance!
MBP 2,4Ghz NVIDIA GeForce 9600M GT, Amsterdam, The Netherlands
faza
Re: duplicate clips
Post by faza »
ok - it's ALT + effect
ferenc
Re: duplicate clips
Post by ferenc »
Haha I was searching for this duplicate function too. Thank u all! I'm glad I discovered this thread before my first live set with Resolume.
gradek
Re: duplicate clips
Post by gradek »
some good tips here Thanks.
