JOYSTICK as Midi Controller
I have a Logitech attack 3 Joystick. Can it be used as Midi Controller. If yes how do I get it to detect by Resolume?
Re: JOYSTICK as Midi Controller
hey Andthen,
Some time ago I used mjoy http://www.otk.it/mjoy/ (Windows) to convert joystick data to MIDI. I think Resolume has no native support for the game port.
Hey thanks
Figured it out. Actually i am using Mac, Used junXion © v1.4 to detect my joystick as a midi controller. Still figuring out how to program the keys, but its working:)
And then
And then
hi !
i am new in this...i want to know if a :
M-AUDIO X-Session Pro, it´s a dj´s USB conection mixer.
can be use for Vj´and if the resolume is compatible.
thanks
thanks
Yes you can use that unit just fine.andres1980 wrote:hi !
thanks
I've used all sorts of M-Audio devices... from the X-Session, to the Oxygen8 to the Trigger Finger.
If you don't yet have a device, there are really cheap units available from KORG which may suffice: http://www.korg.com/gear/info.asp?a_pro ... egory_id=8
VJ Wuzzle
Shakti Collective - Toronto, Canada
