the faq says
how much is necessary? for example: Is 128 MB dedicated RAM enough?In a laptop you should look for a dedicated GPU that does not share the RAM
an how can i find out which mobile graphic card is comparable or better than those?But it is not necessary to break you entire budget on a video card, a basic ATI Radeon HD 2600 (or later) or nVidia GeForce 8600 (or later) will do just fine.
Would be fine if anyone could help me, i run resolume 3 on my desktop PC and it worked great, but i need to know what kind of laptop i should get
thank you
