Resolume error on exit, Vista SP1
gpvillamil
Post by gpvillamil »
I've noticed a rather odd error in Resolume 2.41 running on Vista.
Every time I exit the program (decks loaded or not, video playing or not), when I quit, I get the "Resolume 2.41 has stopped working. Windows is looking for a solution to the problem."
Now the odd thing is that Resolume was working *perfectly* on two Vista machines - in spite of all the issues with Vista, it seems to work fine, better than it ever did with XP. On two different machines, no errors at all, ever. Then on the same day, on both machines, it now gives this odd error on exit.
What could be going on? Is there any way to turn logging on and find out?
gpvillamil
Re: Resolume error on exit, Vista SP1
Found it.
It's the Inside-Us-All 1, 2, and 4 beat swap mixers that were causing the problem. No longer necessary in Res 2.4 since it has the BPM feature.
