flickering video
chadd_
Post by chadd_ »
odd problem here.
i have been using resolume for a while with no problems at all. after i updated my nvidia drivers, i developed a flickering video problem.
the output in the second monitor will flicker at various speeds. if i adjust the playspeed of the clip, i can usually get rid of it, and it only seems to happen when there is only 1 (and sometimes 2) video layers active. it never happens when all 3 layers are active.
i can sometimes fix it as well by adding video to the 3rd layer, and turning the transparency of that layer all the way down, so it is there but invisible, and the flickering of the other layers is gone.
anyone else have this problem? is it a Nvidia driver issue? should i try a resolume reinstall?
thanks, and any help would be appreciated.
rogerlcoco_
Post by rogerlcoco_ »
same problem when I updated to nvidia driver 44.71,
I try to find my old drivers :(
how you you set the output to fill the whole second screen? by setting is to fullscreen or by maximizing it? try if using one or the other prevents this flickering ... see the manual for more info: http://www.resolume.com/support/manual/index.html#dua
chadd_
Post by chadd_ »
i set the output to fill the second monitor by: clicking dual monitor > pressing ctrl+alt+2 > pressing ctrl+alt+enter
is there another way i don't know of?
chadd_
Post by chadd_ »
anyone else have this flickering problem and found a way to solve it?
kio_
Post by kio_ »
i've seen yhe flickering appears only if i have just 1 layer and on 100% of opacity,
if i put another layer and reduce the opacity just to 98% the flickering disappear, ..............
but this doesn't solve the problem
Prolo_
Post by Prolo_ »
Damned, I have this problem too.
With an n'vidia card too (my drivers are 45.91)
Thanks :), I'll try your tips.
(Does anyone have news or fix with other drivers??)
NoddY_
Post by NoddY_ »
Hm... I've had the same problem and ...
I have got it now... with media in cinepak and indeo, in others problem seems to doesn't exists... strange..
Try this:
Try to set the output not "scale to current monitor", but if your output is in 800x600 click on "dual monitor/800x600" and move window by mouse to the output (it's not proffesional, I know:)...
I suppose that the problem is in keyframe every 1 frame. My intuition tells me that :)
I have Nvidia, 44.03 driver... I'll try some other drivers and will tell you son ... hhhhmmm... I mean soon ... ;)
Greets...
