using old decks
DAS BEN
using old decks
Post by DAS BEN »
is there a possibility to use the old resolume decks, or just to reload the clips? i created over the years so many great decks and i would take so much time to rebuild them all.
levon
Re: using old decks
Post by levon »
No i wouldnt think so. the new format is all XML, the old one wasnt as nice to read.
also you would be missing most of your FF effects.
VJzoo
Re: using old decks
Post by VJzoo »
ah...it would be awesome if it was possible to import them somehow but i know its prob to hard to write an importer ;)
Jas
(the dyslexic VJzoo)
http://vjzoo.com
~ quite nice visuals ~
