Open psd files in resolume3
halasz
Post by halasz »
resolume 2 was able to open and display psd files. it was an awesome feature, because we could create texts very easily. i've created the psd once, and when i wanted to change text, i simply did it and saved the document, and resolume was able to refresh it and display the new picture.
eg: text.psd was on the Q shortcut. when i edited the psd, i dont have to save it to a separate jpeg, just simply save the psd, press the q button and the new image is displayed. (i think the only requirement was to turn on the "maximize psd compatibility" at photoshop's settings)
But in res3, i cannot see psd files in the file browser. is this will be available in the final build?
Beige
Re: Open psd files in resolume3
Post by Beige »
2nded. Makes it easier to work on still graphics with Photoshop without having to export them via Save for web.
levon
Post by levon »
It would be cool if you could have 1 photoshop file, and loading it into resolume would put each layer of the PSD onto a different layer. since resolume can now use transparencies, it would be awesome.
