that resolume remembers the size and position of the docked window , everytime it restarts after a crash..
that the resolume workscreen could also work on a 1600 x 1280 monitor , so you get more movies to choose..
we at photonic visulas have thousands of movies , and it's a hell to make thumbnail decks , especially if you're also swapping content a lot , so a separate deck-builder-program to database different computers and their decks , and synchronise them..
a benchmark object , so you can check yourself where your personal bottleneck is.(graphiccard/harddisk/cpu)
multiple tabs of decks.. so you can choose more movies..
a colour filter for every colour of the spectrum , or a hue filter. the best situation is by the universal light-filter sheet rules, ask your local light technician in the disco...or avolites..
an autostart deck that loads when a resolume is starting up
a que-list function ,
12/12/2003 at 23:55:00 countdownmovie1.avi will start 12/12/2003 at 23:59:50
countdownmovie2.avi will start
superb for theater and repeating shows per hour or 20 minutes
drag and drop ! avi's from an explorer window , dropped on resolume..
ctrl-c ,x and v to copy and paste the active movie , between deck positions
new functions please...
- A hue saturation whit the colorize option, same as a Photoshop hue saturation tools.
- Translucent background for flash movies and enabling action script.
- enabling the ".png" file format whit 24bits color and 8bits translucency
- enabling video whit alpha channel in 8bits
- A reel text tool
- The possibility to adjust effect before applying (it is possible now???)
- The possibility to assign a color and resolume make this color translucent, in the style of a blue screen and complex transparency, not just visible or invisible
câest ca
merci!
thanks
