when i add a mask to the composition propertys ( or the layer or individual video ) the image gets slightly less bright / a bit darker, when you put multiple masks on, it gets even darker. its just about ok when you are using one mask, but when you start to combine composition and layer masks it becomes more of a problem ( i combine both which allows me to "sort of" emulate the IUA hex plugin )
is anyone else experiencing this?
is there a work around?
is it on the to-do list?
thanks.
Arran.
