Use 5400 rpm laptop and E-Sata
xander321
Post by xander321 »
Does anyone know if it's a good idea to run Vista on a 5400 rpm internal laptop HDD and to put resolume and the video material on a 10.000 rpm external E-Sata disk. Or do I really need a 7200 rpm laptop hdd to get good performance.
Thank you!!
Xander
edwin
Re: Use 5400 rpm laptop and E-Sata
Post by edwin »
I think an external HD is a good idea especially a 10000 rpm one, you could think of having some files running from your internal disk and others from your external disk to spread the load.
