Ohm and resolume
plasmavj
Ohm and resolume
Post by plasmavj »
I have a livid ohm and I am looking to use it with resolume. It seems like it would work perfectly but I need some tips on setting it up. anyone else out there using an ohm? here are the specs if it helps http://lividinstruments.com/hardware_ohm_details.php are there any templates or anything in resolume3 for this?
edwin
Re: Ohm and resolume
Post by edwin »
You should be able to use it ithout problems in Resolume.
Open up the prefrences window and make sure the device is enabled in the MIDI tab.
Then start mapping, choose Contextual MIDI map in the mapping menu, click on a highlighted element in the interface and press a button or move a slider on your Livid.
That should work.
edwin
Post by edwin »
Sorry, i didn't fully answer your question.
There are no templates availbale but if someone else set up the Ohm you can copy the .xml file and load it into Resolume.
plasmavj
Post by plasmavj »
thanks for the information. I will try making an xml file and maybe other people can use it to.
