oww!?
dublicate__
Post by dublicate__ »
hello, after i entered the serial number all the text disappeared. i tried to find the fot1 and fot2.fff files in the program folder, but they aren't there!?
eeeeez,
dublicate
for all of you having problems with the text disappearing, we have updated the trouble shooting section and this should fix the problem:
When resolume starts it creates two files: 'fot1.fff' and 'fot2.fff'. These files contain the fonts used in resolume. If these files are still in the 'C:Program FilesResolume' folder when resolume is not running delete them and start resolume. Usually this solves the problem. It not, start resolume and copy the file: 'fot1.fff' and rename it to 'feisar.ttf'. Copy this file into the 'C:WINDOWSFonts' folder to install this font. Restart resolume and you should definitely be fine.
