cant see the text in the prog !!
shendi_
Post by shendi_ »
cant see tje text ( i read that if i del 2 files it will be ok - there are no files with that name that u said ) ?
even after i restart the prog still
dosnt fix it !!!!
need help !!
Jello_
Post by Jello_ »
I have exactly the same problem!
I deleted the two files, but they get recreated at every startup of the software.
name_
Post by name_ »
try restarting your pc when it happens
shendi_
Post by shendi_ »
nice answer :)
but in a middle of a show willu do that ?
hope the new version will have this fixed
for all of you having problems with the text disappearing, we have updated the trouble shooting section and this should fix the problem:
When resolume starts it creates two files: 'fot1.fff' and 'fot2.fff'. These files contain the fonts used in resolume. If these files are still in the 'C:Program FilesResolume' folder when resolume is not running delete them and start resolume. Usually this solves the problem. It not, start resolume and copy the file: 'fot1.fff' and rename it to 'feisar.ttf'. Copy this file into the 'C:WINDOWSFonts' folder to install this font. Restart resolume and you should definitely be fine.
