Hi, here are some audio features I'd like to see added to Avenue.
It would be good to have a "detach" function in the vst wrapper menus, or at least some feature that allows you to keep vst gui's "in front" so as you can work on both the Avenue gui and the vst gui without the vst closing or the controls in Avenue being disabled.
Something else that would be nice is individual PDC (Plugin delay compensation) for both audio/visuals on the clip layer and composition tabs for when working with compressors or limiters. (compressors will report the latency they're producing to their host apps in most cases). Secondly If a PDC type feature was made available for video and audio on even just the main composition, it would be a lot easier to sync Avenue with your daw.
I know this is on your list already but. . . a decent amount of audio outputs (say 8 or 16) would be a nice touch for people who are wishing to mix down AV composition audio in their daws .
I hope you guys can find time to develop some of these features, they'd really speed up our workflow.
Regards
ni-cad.
