Intel Indeo codec?
Slolov_
Post by Slolov_ »
Hi, because the Cinepac Codec is so slow i use the Intel Indeo codec for my movies in Resolume. Is this okay? I have found no problems using the Indeo codec under Resolume so why should i go for Cinepac codec anyway???
mike ho_
Post by mike ho_ »
I use indeo as the image quality is better, as long as your PC is new & fast and you have no performance issues with multiple layers it should be fine
ether_warpTV_
Post by ether_warpTV_ »
indeo is a far better codec than cinepak. Cinepak is quite old and will play on any machine (PC or Mac), but is definitely not the best codec for live work.
Indeo codec is free for win2k, but i believe there is an XP version which is not free.
