I was playing with the mapping .... and.... surprise surpise while i'm mapping i can create layers, columns and decks... but this are not suitable to map until you don't restart the mapping... i think it will be nice to have all the controls lock while mapping....
The output monitor panel... is it possible to minimize?
The help panel could be nice if it has a scroll for long texts...
If i try to load the demo deck(640x480) to another composition (320x240) is load a new deck with the name but not the clips... and creates a new empti deck
Bugs¿?
Re: Bugs¿?
Output --> Disabledrabosavj wrote:The output monitor panel... is it possible to minimize?
Re: Bugs¿?
Where is that?VJair wrote: Output --> Disabled
Re: Bugs¿?
Output = at pulldown top menu
Disabled = in the Output pulldownmenu
