Hello,
i followed a previous thread about the MIDI Clock not being recognized in beta. To me it worked once with the beta for a couple of minutes and never again.
I upgraded to 3.0.0 and still i can't get the MIDI Clock to work. The yellow indicator blinks but the bpm value is stuck to what is manually assigned / tapped. I tried with all the 3 options for the Midi Start in the settings, still nothing moves.
I receive the clock from a Pioneer DJM-800 passing through an Edirol-V8 (thru port) with an M-Audio Midisport Uno card. I receive correctly the MIDI controls from the mixer while the clock doesn't work, i tried to see if the clock is received using a VVVV routine and it works, together with the other controls... anybody can help?
thanks
vjandrea
MIDI Clock still not recognized
Re: MIDI Clock still not recognized
Resolume will start repsonding to MIDI clock when it receives a MIDI Start message. Untill then it will only indicate it's receiving messages.
Thankyou Edwin, i will try to see if the DJM-800 sends this command or i have to do it manually.
vj andrea
----------- resident @ Jimmy'z (Monte Carlo) ----------
