BUG: Clip Properties shows wrong clip on layer select
craftycurate
Post by craftycurate »
(Cross posted from news forum - better here)
On activating a layer, the currently active clip is highlighted correctly only if the playing clip is in the currently displayed deck.
However, if the clip is in any other deck, Clip Properties does not display the playing clip, but instead the clip from the active deck which resides in the same cell position as the playing clip.
Hope that makes sense?
Richard
Re: BUG: Clip Properties shows wrong clip on layer select
Yes, confirmed. ToDo-ed.
