maximum clip lengths
defasten
Post by defasten »
hi there - Resolume Avenue 3.0.0 is crashing. Is it possibly because i have a few clips at 4 minutes in length? they are 960x560, *.dxv quicktimes. I like to have long clips that I could simply scrub live, but if it's obviously better to trim them down into parts, that's ok.
thanks
racher
Re: maximum clip lengths
Post by racher »
I have the same question. I notice that longer clips definitely play much choppier than shorter clips using the same codec. Much of my animation is ultra smooth, so the choppiness makes my work look like crap. So far, my longest clip is 1:30, but I've shortened this to a minute to get better performance.
-B
