dashboard knobs/mapping (layer / clip)
Rene
Post by Rene »
Hi!
I have discovered a strange behaviour when mapping dashboard knobs of layers. It looks like it is necessary to change the mapping of "Link1" to any other link (e.g. "Link2") and then back to "Link1" to make it work (please see the video (rename to .mov)). Dashboard mappings for clips do not work at all (at least not for me).
Hope it's okay to post a video!?
(a picture says a thousand words; and a 90" video with 8fps == 720000 words ;) )
dash2.mov.zip
(1.51 MiB) Downloaded 571 times
Re: dashboard knobs/mapping (layer / clip)
Rene wrote:I have discovered a strange behaviour when mapping dashboard knobs of layers. It looks like it is necessary to change the mapping of "Link1" to any other link (e.g. "Link2") and then back to "Link1" to make it work
Hmm I see that it's indeed going "wrong" when there is no clip playing in any of the layers.
Rene wrote:Dashboard mappings for clips do not work at all (at least not for me).
Same here, if the clip is not playing the dashboard dials indeed do not link correctly, when it does play it works fine. We,ll see if we can fix this.
Rene
Post by Rene »
Thanks for your answer, Bart.
Just to let you know: if I run a clip (in a layer) and add a clip effect, it works the same way like layer effects do. (switch from "Link1" to "Link2" and back to "Link1" and everything is in sync)
