Quicktime MJPEG movies not playing in Res2.41
gpvillamil
Post by gpvillamil »
Having a weird problem here: Quicktime movies encoded in MJPEG don't seem to be playing in Resolume 2.41.
Basically, the movies load, the thumbnails are generated, when clicked they appear in the layer window, the scrubbing cursor moves... but the movie does not play.
Manually scrubbing seems to work, it scrubs through the movie, but when you stop scrubbing, it doesn't actually play.
The clips are all 640x480 MJPEG-A at 80% quality. They contain the default Quicktime sound (QDesign). The same clips in PicVideo MJPEG in AVI format play fine.
HerrNieDa
Re: Quicktime MJPEG movies not playing in Res2.41
Post by HerrNieDa »
i never get quicktime videos running on resolume2 to work with
with fotojpeg i can play it very good but only 1 file and at loading resolume stands still for 2 seconds..
just this one file after once played i can run again without a lag, a new quicktime video makes the same problem!
indeo is best codec for resolume so long, mjpeg avi codecs are also good but i don't like the artefacts you get at gradients f.e.!
ERPMSOFT.COM
Post by ERPMSOFT.COM »
hmm have this problem to..
E-RPMSOFT.COM
3367930285
HerrNieDa
Post by HerrNieDa »
it's not a problem, it's a feature :roll:
