IN-OUT POINTS
incuf
IN-OUT POINTS
Post by incuf »
It would be nice to grab the timeline in between IN-OUT points and be able to move IN & OUT points together.
cheers
IncuF
Re: IN-OUT POINTS
I was going to say that holding down SHIFT while moving the in our outpoint would move the range but that does not quite work as well as it should. We,ll have a look why.
Rene
Re: IN-OUT POINTS
Post by Rene »
Yeah! - if the clip is paused, "SHIFT"-key while moving the IN point works ;) - thanks for this hint!
incuf
Re: IN-OUT POINTS
Post by incuf »
It should work with a playing clip, for sure. Don't worry, they will fix it, no doubt about it.
cheers
IncuF
incuf
Re: IN-OUT POINTS
Post by incuf »
Moving IN & OUT points together holding SHIFT key. still doesn't work.
cheers
IncuF
