Using Acid loops in Resolume
vjloco
Post by vjloco »
I am experimenting with the audio loop feature of Avenue, and noticed that if I want to use Acid loops I need to open them in acid and then render each loop at the tempo of the Avenue composition if I want them at the correct pitch.
Also, is it true that if I want my video loops to run at 100% speed they have to be the exact same length as the audio clip?
I would like to hear other users' feedback on how they work with audio loops in Avenue.
Laptop: Intel Core 2cpu T7200 @2Ghz - 2Gig Ram
Operating system: Windows Vista Ultimate Sp1 X64
Video card: NVIDIA Gforce Go 7600
Re: Using Acid loops in Resolume
vjloco wrote:if I want to use Acid loops I need to open them in acid and then render each loop at the tempo of the Avenue composition if I want them at the correct pitch
Correct, we do not support Acid loops at the moment.
vjloco wrote:Also, is it true that if I want my video loops to run at 100% speed they have to be the exact same length as the audio clip?
Yes this is correct. As a workaround you could put the audio and video in different clips above each other and then trigger them at the same time with the column. This way they start at the same time but can each have their own tempo.
