Resolume Wont play the videos realtime, any idea?
joematouk
Post by joematouk »
helloooo all,
am making a visuals that include text for couple of tunes the problem is its working perfictly out of resolume but wen i play them on resolume you can see that it moves slower or faster so the sink is no longer ther, although am sure to play them on 25fps as the original video, any ideas?
VJair
Re: Resolume Wont play the videos realtime, any idea?
Post by VJair »
what format are the videos you are trying to play? are they in any of the reccomended formats?
joematouk
Post by joematouk »
am exporting them as .avi (H.264) which seems to play perfectly on resolume if am not looking for sink or real time play, very light nd stable , please advise wut should i convert them to?
thank you so much for your help
VJair
Post by VJair »
have a look in the manual for reccomended codecs and compressions. theres a folder in your resolume folder called manual, open the index.html file
gradek
Post by gradek »
joematouk wrote:am exporting them as .avi (H.264) which seems to play perfectly on resolume if am not looking for sink or real time play, very light nd stable , please advise wut should i convert them to?
Hi Joematouk,
H.264 files are no good in resolume. H.264 is a great compression formats, however its requires too much processor power to decode the video for realtime mixing. too bad, since the quality and file size is the best! Someday perhpas... Until then I recommend you upgrade to version 3.0 and use the DVX codec. its super fast and utilized the GPU on your graphics card to ease the load on the CPU.
